Guages
not that hard at all...itll take you an hour or so. All you have to do is remove the gauge cluster and then pop off the old face and stick the new one on. One thing to be careful of is that when you take the needles off the face make sure you put them on in the exact same position, otherwise your gauges will be off. Other than that it shouldnt be too difficult for ya. Good luck with it.
ORIGINAL: BallinBloye
How difficult is it to install new guages on a 99 GT
just be careful fooling around taking out/putting back in the cluster as it is all plastic that is 6 years old and may be a little brittle. Also, stressing again the fact that you should make sure the needles are on correctly or your gonna have problems getting it right.
Dearborn5.0
Aug 9, 2004 10:42 AM
