installing underdrive pullies
Old Apr 12, 2008 | 04:06 PM
silverstang1996's Avatar
silverstang1996
Default RE: installing underdrive pullies
how did you guys take the bolts off the pulleys when turning them the pulley itself turned and you couldn't get the bolt loose? i had to use an impact gun on the alternator and balancer(as someone else said i had to take the electric fan out for the gun to fit for the balancer), and i had a hell of a time taking the water pump bolts off because the pulley just kept going around instead of the bolt.
Old Apr 12, 2008 | 11:34 PM
MineralGrey's Avatar
MineralGrey
your supposed to loosen/tighten while the belt is still on to help you out. Here check this out my answer any questions you may come accross http://autohow.tv/node/13
Old Apr 12, 2008 | 11:49 PM
silverstang1996
ORIGINAL: MineralGrey
well that's the thing, even with the belt on the pullies still slipped hah
Old Apr 13, 2008 | 05:10 PM
Mjaga251's Avatar
Mjaga251
Check out that video above, that should help you out...
IMO, get Steeda's UDP
mtgldr
Feb 3, 2024 09:00 PM
ctgreddy
Sep 20, 2015 08:35 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
Sep 10, 2015 08:39 PM
