1996 Mustang GT Leak Confusion
RE: 1996 Mustang GT Leak Confusion
ORIGINAL: BlackMUstang96GT
It might be the intake manifold, it could be cracked and could be leaking antifreeze. That happened to me and once i looked underneath the hood with the engine running i could see antifreeze squirting out of the crossover, it had a little crack in it, i replaced it with one with analuminum crossover intake manifoldand havent had a problem since. You could try replacing it with analuminum crossover intake manifold and see if that stops it. It wasnt too hard to put the new intake on.
ORIGINAL: DamenR
Well I had it running and I can't see any leaks anywhere, is it possible that it's a very slow leak or something? I'm sorry for all the questions, I just want to make sure what the problem is before I begin ripping things apart, heh.
I'm still not quite sure where it's coming from, the hood was dry, everything was dry, but those four spark plugs are still soaked, intake manifolds are expensive, could it just be the gasket or would I have to replace the whole manifold?
My 98 has the same problem... leaks maybe a cup of coolant every three months and has the same spark plug issue. the manifold is actually cracked where the hose mounts on it in the back on the passenger side. barely leaks at all but after time it is noticeable. Check there.. you will need a flashlight. I thought mine was just loose at first until i took off some parts to get a closer look. Your problem sounds just like mine so I am pretty sure it is something very similar.
Well if you decide to buy the aluminum crossover intake manifold heres a link- http://www.latemodelrestoration.com/...1&comp=LRSit cost $250 paid alittle more for mine. It has everything u need to install it.
So I finally caved and bought a new intake manifold because it is fairly unanimous that, that is the problem, so it should be here sometime this week, any tips on installation or is it fairly simple?
ORIGINAL: DamenR
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
91StangOwner
08-20-2015 11:34 PM
08-11-2015 03:43 PM
