Motor Mounts keep breakin
Hola......
I've just got one quick question. Lately over the last few months (maybe a year) Ive had to replace the same motor mount twice....the right (passenger?) side. I wanted to get a personal opinion from you guys.....would it be a good idea to put a chain on that side..... I thought it could work...My dad has chains on his car, he had the same problem, 81 el camino, built 350, 450+ rwhp.... good idea or no?
(sorry bout the double post, damn dell, lol)
RE: Motor Mounts keep breakin
You shouldn't be breaking mounts like that. Are they stock Ford mounts? Are you sure your engine is sitting evenly in the k member, not shifted to one side? It sounds like you have some sort of issue with the alignment of the engine (or just really bad luck) thats causing the mount to break. Its kind of tight under there. Im not sure how you'd get a chain to hold everything in place (or how it would prevent the mount from breaking again), I guess you could try it though. Personally, Id look for the cause of the broken mount, there's gotta be something wrong if you're on your third mount on that side only...
Did you do the mounts yourself?? Did you make sure to torque them down correctly (correct torque rating)???
Unless you're bouncing on the gas constantly, it's tough to say why they'd break,besides what Mark99GT said...
JT
JT
They are stock for mounts...and everything is torqued down right, by the book...and yes, I do alot of racing.....maybe its the nittos....I did put the chain on it today... I have yet to do a road test.. I'll let you guys know.
ORIGINAL: mills281e
Would a tranny brace help?
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
