Im thinkin my tuner might be off?
RE: Im thinkin my tuner might be off?
You must not have been racing these cars very long. With drag radials and nothing else a new edge can run 9.3. An x pipe produces more hp then an h by about 5 hp and the high flow cats on aftermarket midpipes takes 2 hp away.
I was running sub 9s with just front suspension, Hpipe, flows and drag radial. I now run 7.8 NA with whats in my sig plus some I couldn't fit.
Thanks for rubbing it in miller, haha, both you and vogel running 8.9's with about the same mods as me. Jim said that he didnt have the gears yet when he ran his first 8.9.just the underdrives, catback, and midpipe.
And yeah lemme know whenevers good for you for the differential swap. Got the royal purple just chillin in the garage.
So did i read all this right? The tune isnt off? or is it?[&:]
ORIGINAL: GStam66
ORIGINAL: timeformiller44
^^ lol well george has a catted x with tires and a tune.. no o/h no tb/plenum also it says sniper tuned on ur sig not diablo for the vert. plus george did say it was a hot day which it was and was getting faster but track closed i guess..also i dont think he knew how to use the drag radials yet
george this weekend ill do your rear end get that damn thing fix...(reverse burnout) failed and the horrible noises it made.... but yeah im going ot get that bearing pressed on prob friday and itll take like an hour to swap that crap out..prob wont effect much but we will see u need it anyways
Nooo, it wasnt a hot day, the engine was just running hot. twice i had back to back runs. Probably shoulda just pulled off to the side for a bit, my own fault.
ernesto-619
09-10-2015 01:32 AM
