99 GT manual tranny fluid change
RE: 99 GT manual tranny fluid change
what do you wanna know? how to do it?
your 99 GT has the T45 in it (or, should if it hasnt been screwed with).. two bolts on the transmission.. the lower one is for draining, the one higher up for filling. Both plugs are able to be taken out by a standard 3/8 Ratchet. your going to need some sort of suction device to add fluid back into the transmission on the T45 because the location of the add plug totally sucks.. OR you can take out the shifter and add fluid from inside the car..
..the transmission takes MERCON V
