springs
springs
hey, i dont have much knowlege on suspension work......so i gota few questions...
if i get sum lowering springs, will i havta do anythin else to the suspension? im broke!
plus wut springs should i get?? any advice would help
RE: springs
don't get MAC springs, i bought 2" lowering mac springs, and when im not driving it looks like it sits just as high, but someone told me today when i passed him it looked lower, not sure whats up with that. I was told if you go lower than like 1.5 inches you need to get camber/caster plates or else you will have premature tire wear. I'd go with EIBACH if i did it all over again, which i will in the future. Also someone said i should get new actuators or something like that. thought i'd save you the heartache of spending 300 dollars like i did and not even get my car lowered like i wanted with MAC springs
RE: springs
If you are going to replace your springs, you might as well replace the shocks/struts at the same time, you have everything taken apart so it is not that much more work. When I do mine I will do all at the same time.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
