problem...
Old Jun 10, 2008 | 07:32 PM
prochargedGT's Avatar
prochargedGT
Default problem...
i was on my way home from work when suddenly my car died and when i started it back up it wouldnt idle unless i give it gas and then even when i give it gas its breaking up almost like it has a cam in it...there is no knocking what so ever, didnt throw any engine codes, the oil is clean as a whistle, the only thing is that when i hold the gas in say 2500 and its sputtering or what have you, if i got wot itwont sputter it revs but then when the rpms fall down it dies agian.when holding it at a steady rev it will sound like its backfiring but its coming from around the headers when it does so...i do know that its running a 9.8 on the a/f ratio and when i pulled the plugs (thought that was the problem) they were fouled and it still does it with the new plugs. the car was running some what descent on the 9.8 but i do know thats really rich so any input would be helpful. my mods are in my sig.
Old Jun 10, 2008 | 08:23 PM
Roy_R's Avatar
Roy_R
Default RE: problem...
Fuel Management Unit (FMU)???
Old Jun 10, 2008 | 08:35 PM
Mr Graystang's Avatar
Mr Graystang
Bad fuel delivery ? did you check the filter ? or pump ?
Old Jun 11, 2008 | 05:55 PM
prochargedGT
i just replaced the fuel filter like 1000 miles ago and the fuel pump is probably 10 months old...and i can also hear it when i put the key to the on position i know thats not a for sure way to tell but....anyone know if there is a chance if it could be the maf?
Old Jun 11, 2008 | 07:08 PM
blackstallion666's Avatar
blackstallion666
have you tried disconnecting the maf and see whats happens?
Old Jun 15, 2008 | 07:23 PM
blstoff's Avatar
blstoff
hey man, give me a call . I think your timing chain has jumped a tooth . yeah yeah, I know .
fablefifty
Dec 29, 2006 10:32 PM
x9Mustang9x
Dec 14, 2006 02:20 PM
Airman21
Nov 17, 2006 04:10 AM
XXC
Sep 19, 2006 05:12 AM
mstng675l
May 25, 2005 03:02 AM
