SNIPER TUNER SOFTWARE @ PI SWAP
I was looking at the sniper tuning software for my car, im doing the pi swap and need to tune the car, is the sniper tuning software good for my mods, pi swap-k@n-hpipe-underdrives-, if not what should i get for a tune??
RE: SNIPER TUNER SOFTWARE @ PI SWAP
Are you doing the heads too? If not then there's really nothing special to tune for. The MAF will measure the engine's better breathing and the PCM willdetermine the appropriate amount of fuel to go with it. Same is true for the K&N (which does nothing), and the H-pipe which just makes the engine breath metered air better as well.[/align][/align]If you doing the heads too, then the Sniper SF package will let you enter the new compression ratio which will be up around 10.25:1 (or so) after the swap.[/align][/align]Sniper'sRecon data logging software (which comes with all Sniper packages) will let you log the MAF voltage to make sure it doesn't peg, it shouldn't...[/align][/align]
Matt's 95 Stang
10-05-2015 07:16 AM
