ABS & traction lights
Old Jun 28, 2008 | 12:45 PM
tafet's Avatar
tafet
Default ABS & traction lights
Here what I have. I replaced the rear diff cover with a girdle and filled it with 75W140 gear oil. Now every so often my ABS light will pop on then the ABS light. If I apply the brake they both go out and it won't come back for about a week. Has any one seen this? Thanks
Old Jun 28, 2008 | 01:17 PM
ShadowDrake's Avatar
ShadowDrake
Default RE: ABS & traction lights
Strange, one of your ABS sensors may be damaged? Maybe your ABS module is failing?
When it comes on, see if you can make it to a place that can scan the ABS diagnostic code (NOT the same as an ECU code)... and see what it says the problem is. That's the best way to figure out exactly what's wrong. Changing the oil in the rear shouldn't have any effect on those systems unless something was damaged in the process.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
ChampInSD
Oct 2, 2015 04:55 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
