Oil is mixing with coolant...
Yesterday i noticed that my coolant is disgusting. I recently did the PI swap and now my coolant is ****ed. My first thought was **** a headgasket is ****ed. But my oil in the pan looks fine, the car doesn't over heat(doesn't even reach the m in normal) and the car blows no smoke at all from the tail pipes. I did have the heads off the car for a while behind my house surrounded by trees which i thought maybe pollen or something got in the coolant passeges in the block and the coolant is just dirty. Either way im going to completely drain and flush the coolant and see if it happens again. Is it possible for the coolant and oil to mix and it not be a headgasket? I did have a intake manifold gasket rip on me after the swap not sure if that means anything. And how bad would it be to drive if just the oil was mixing with my coolant and not the other way around. I know it needs to be fixed but i start auto tech school in sep so maybe if it can wait ill do it at school.
RE: Oil is mixing with coolant...
its one of 3 things or even all 3 but not likely.
one a head gasket inthat caseyou need to pressure test it they make a simple kit anyone can use.
two intake that again id do the same for
third a cracked head
Sounds to me like you may have caught it early enough to prevent any real damage.Either way though coolant in the oil or oil in the coolant is bad.
If you tore the intake gasket thats a good start to check.For future reference do not use parts you get or damage yourself this could have costed you an engine.If it hasnt yet
Also to help you better try using that dye for the coolant to detect leaks it works very well.
Sounds to me like you got some oil in the water jackets while pulling the head off. It happens all the time. If it was a blown head gasket or cracked head you would have water in your oil as well. It would go both ways.
Monday i will be completely draining and flushing the cooling system and see what happens. If it is the head gasket it would have to be where the oil is under extreme preassure to push it into a coolant passage. The only oil feed hole is on the side and is far from coolant passages but i guess its still possible. Either way my fingers are crossed and hoping for the best.
jwog666
12-27-2021 08:09 PM
