pi head swap question
if i put pi heads on a 98 mustang will the stock intake fit and how much modification is there in this swap and does the motor have to be pulled
also how hard is it to put long tube headers on this car
RE: pi head swap question
The stock npi intake is just a bad as the npi heads, best to swap the intake and heads together. The motor shouldnt have to be pulled but its easier to deal with the timing chains and what not, same goes for puttin lt's on there.
o ok because my friend is selling me pi heads and intake for 100 and i want to put lt's on it this winter while its doing nothing in the garage but im undecided weather or not i should buy the tranny from him too becasue it has a shift kit and i could get it for 150 so idk wut i should do any suggestions
o and how much moification is there to put on pi heads and intake
If you get a set of romeo heads, there is a lot less diffences in them, you will still need a pi coolant tube that runs beside the new pi intake instead of trying to go under it. You may need a dipstick I can't remember if I used mine or not. If you get a set of windsor heads you will need bigger timing case cover bolts and new valve covers aswell. It's not a big deal to use either heads, I've got windsor heads on my car. If you new pi intake doesnt have 2 temp sensor holes then you will need to drill and tap a new hole for the second one on the 98 harness, however if you have an updated 98 intake with an aluminum crossover then you can just swap them out if your pi intake had an aluminum crossover.
when im changing the heads the only thing im worryed about is the timing how do i no tht the timing is right
i was planing on takeing the old motor and puttting the key way on the crack up and marking the crank and chain and cam and chain and then putting the keyway on my motor up and then just try to get it right but idk if it wil all work out are there any tricks
Luke9222
10-22-2015 11:55 PM
