Oil Pressure problems
That sounds about right. On cold start...oil pressure at cold idle...is around 80 psi on my autometer guage...assuming the guage is accurate? When I give it a little rev it jumps to 90 and rev little higher...I've seen it peg my guage at about a 100psi. I first I thought this can't be right? But I guess ford assembled these engines under tight tolerances. When the oil warms up at idle it is about 18-20 psi. Which seems lower than the rating they give...but like I said that is idle. Ford's rating I think is what was said earlier at right around 1500rpms...which would be higher than stock idle.
I remember my old 91 5.0, the oil pressure in that thing never got above 55psi even at cold pressure. So seeing a high number like that kind of shocked me too when I seen it that high and then go down so much.
zanemoseley
Sep 6, 2015 12:58 PM
