someone educate me on stroker kits.
#51
RE: someone educate me on stroker kits.
ORIGINAL: yellow034.6
no im not going anywhere im sry you wanna bees dont know what your talking about but i am going to stop posting about this subject because 99% of you know nothing at all about how to build an engine1slo85 oxford sxynerd livefast1 and alot of others.
arguing with you guys is like running a race in the special olympics,even if you do win(which you wont)your still a retard.[:-]
im done with this topic if anyone wants to know some real facts about how to build a real engine instead of beleaving these guys bs shoot me a pm
Completely built to the hilt 4.6L 2v and it made what, 360~ whp right code?
491 WHP... gtfo.there are simply put NO 400+ WHP stroked 2v cars out there, period (n/a). i have seen some completely and utterly wild/unstreetable bore/stroke cars out there, but boring is an entirely different manner, and ALOT more money.
Stroking a 2v does NOTHING. Anything you can do with a stroked 2v you can do better with a stock CI 2v. your talking about adding a mighty 21 ci here folks... on a already poor bore/stroke ratio setup.
#52
I wonder if anyone took him up on his offer??
Is he banned, or not?? I really want to ask about the real way to build engine.
#53
so another question. what compression ratio should i go after. sean hyland is under the impression that anything over stock is a waste, stating combustion chamber of the PI heads as the reason. I have read in other articles and books of engines running 11.5:1 and making very impressive numbers. So what say you experts?
#54
Increasing compression will give you gains just not huge ones. You wont be able to run as much timing with pump gas. If this is your daily driver I would stick with stock compression. Sean hyland is right (can't believe I just said that) about the poorly designed combustion chambers.
KingRando
10-02-2015 08:06 AM
