Aftermarket Steering Wheel
RE: Aftermarket Steering Wheel
Here's one of my other wheels, this is also a Grant; it's their 1080 model with the real leather cover (with the same center piece and horn button):[/align][/align][/align]
ORIGINAL: cliffyk
The wooden wheel looks like its some kind of old mans car
another question for cliff, where did you get that gear selection where your coin holder used to be? ive been looking for a 6 speed one, and no luck. hopefully you help me.
ORIGINAL: maxersloan
hey cliff, i know its off topic but how did you paint all your dash pieces? it looks awesome!
ORIGINAL: 562cobra
ORIGINAL: cliffyk
[/align][/align]That's Duplicolor's silver wheel paint, 2-3 coats and it's durable as heck. Degrease with Prep-All or similar, and then wipe down with denatured alcohol just before shooting. Make sure the temp is over 70° F because the paint likes to "spit" if it's too cold.[/align][/align]Duplicolor has a clear coat wheel paint as well if you want a very glossy finish.[/align][/align]Not that you asked, however in my years I have found that Rustoleum's "Satin" series black paint is the best thing there is for both interior and exterior satin finish black. As evidence of this, I prepped my GT emblems and the pony's corral as described above, and "blacked" them out using that paint over a year and 40k miles ago, it has not peeled or chipped in that time.[/align]
Yup, they all come off...[/align][/align]For the shifter surround/bezel just remove the shift **** and then lift the surround pretty much straight up with your fimget nails under the outside edges, it will pull off.[/align][/align]The radio/HVAC control surround has two screws at the bottom that you'll see when the shift bezel is off. Remove those, then pull the bottom of the radio/HVAC surround rearward. Pull steadily and gently and work your way around the perimeter to get each of the spring clips to release.[/align][/align]The vents can be pried out using a thin flat blade screwdriver padded with 3 or 3 layers of electrical tape.[/align][/align]
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
09-08-2015 11:50 AM
