installing long tubes?
Old 09-10-2008, 08:31 AM
  #21
jjandascog
jjandascog's Avatar
I find it interesting that alot of people on here just agree with whoever,or they dont have the mechanical ability to figure out the easiest and best way. When I do this,im gonna time it and take pics, but they will still say it cant be done......
I am wanting to install headers myself, that would be great if you took the time to take some pics while you work of your install (not dropping the k-member) for the rest of us who have not done this yet.
jjandascog is offline
Old 09-10-2008, 09:22 AM
  #22
pcs
pcs's Avatar
Originally Posted by boostanggt
IMO it's a matter of how much you're rushing the project. If you're in no rush and want to make sure you're job is %100 without leaks, dropping the k member is the best bet. The quickest route is obviously just to jack the motor up.
it sounds like you are implying that jacking the engine over is a cheap short cut and that the correct way is to remove the k member. well its not, i dont have leaks and im sure many other people that have just tilted the engine also dont have leaks. also, if you read the instructions for installing lt, such as bbk, mac, bassani, ect. they also say to tilt the engine, not remove the k member. if you search though mm&ff old tech articles, they installed lt on a cobra, on car lift. they also tilted the engine. so i would say to you , if you want to wasted time installing lt and throw off your cars alignment off, drop the k member.
pcs is offline
Old 09-10-2008, 11:56 AM
  #23
boostanggt
boostanggt's Avatar
HA the instructions say that because they want you to think the job isn't as bad as it really is. Jacking the motor up is the EASIEST route. I would much rather take my time. It is not hard at all to take off the k member. Take whatever route you please.
boostanggt is offline
Old 09-10-2008, 02:20 PM
  #24
98redstang
98redstang's Avatar
to 97 im not saying your cant put in your .02's to help but your saying it CANT be done which isnt true thats all im saying.
98redstang is offline
Old 09-15-2008, 04:48 PM
  #25
pcs
pcs's Avatar
i have also swapped out my k member so i know that its not hard to remove, just a waste of time for a lt install.
pcs is offline
Granatelli Sales
01-20-2020 12:34 AM
msavoia23
12
07-07-2018 12:08 PM
SYNY5TER
09-02-2015 01:35 AM
GimpyHSHS
08-29-2015 06:30 PM
5.0pntydrpr
08-27-2015 10:26 PM
Quick Reply: installing long tubes?
