Fuel pump Questions
Fuel pump Questions
I was wondering if someone could give me some advice about fuel pumps. I took my stang in for a test and the fuel pump ended up being bad. It was running at 15psi instead of 38psi. real ****ty. I really don't feel like paying $300 for a STOCK fuel pump. This just gives me an excuse to buy a performance one. I would like some recommendations on some aftermarket fuel pumps. here is one i was looking at, do i need to buy any other parts to make this work?
http://www.americanmuscle.com/bbk-fuel-pump-255lph.html
thank you!
thank you!
You have a 98, which means you have the most clusterfvcked fuel setup Ford has produced. You'll know what I mean when you dig in there.
A focus pump will drop right in, as well as the Aviator pump. The Aviator pump will flow enough to support ~450rwhp in the future and is rather cheap (ie. ~$170)
A walbro or BBK pump like above will need the bucket modified to fit in the 98 model year only.
when i searched aviator pump i came up with this.
http://www.speedconcepts.net/product...roducts_id=743
will this work?
thanks bro
will this work?
thanks bro
will this work?
thanks bro
will this work?
thanks bro
However, call Randy Stinchcomb at Liberty Ford (ph # 410-655-2000 ext is 5618) and he'll set you up at a better price.
The focus pump will work too, and is about half the cost. However, it's generally done at ~360-390rwhp.
Nope, this is the one: http://www.speedconcepts.net/product...roducts_id=710
I suggest you buy it from Randy. He has the best prices on factory Ford parts, and you will get it VERY fast through shipping.
The above "Gerotor' pumps will not last very long as the 98 pump is a return style but not like the 86-97 gerotor as it's a turbine like the returnless style 99+ that it has a varied voltage that will kill a gerotor pump. Your best bet is to keep the stocker and add an inline pump if going forced induction. If you modify the basket on a 98 tank you will cause fuel starvation below a half tank which will cause a lean condition and you'll be sweeping the streets if you get my drift. When I went with F/I I got a tank, regulator, and filler neck from a 97 and I'm good to go!
