Traction control indication
hello all!
I bought a couple of weeks ago a 2000 GT.
It has traction control, and it is working. I get the indication in the dash when the wheels spin, and the engine bogs down, but I don't have an indication if it's switched on or off ... no light on the switch, or on the Dash ...
Anyone know what's missing?
10x,
Yakir
10x,
Yakir
well the light may have burned out, or a bad connection to it. It obviously works, however try pushing the button and see if it will turn off, go do a burnout and see if it keeps you from doing it. I would say take it apart and check for voltage going to the light
Thanks for the reply!
Only problem is I can't find where the light is supposed to be ... In the switch? there is no light there ... On the Dash??
And it does have traction control ...
If I could only find where the light is supposed to be, I would start from there.
Maybe I will start with taking the button apart, maybe it's not the original one, and the original had a light in it, like the new ones do.
the light should be above the words on the switch. you know how it has the rectangular button behind your shifter to turn it off and on?? the light is small but it is on that button and when turned off the light will be orange
my car is also a 2000. the light is on the switch and should say off when you push it. however i have had mine not light up before and then one day it started working again. try pushing the button then doing a burnout if it doesnt bog the traction control is off
Now I know that the switch is probably not original, and I will take it apart and check if I can put a light somewhere to have the indication.
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
