5.4 Liter Swap????
Old 05-21-2005, 01:17 AM
David_K
David_K's Avatar
Default RE: 5.4 Liter Swap????
do the 5.4 swap. NE-one else done it????? then youl be the first and well have to ask you questions about it instead of taking peoples words
David_K is offline
Old 05-21-2005, 03:04 AM
00GT00
00GT00's Avatar
85k, not worth it! It would need a rebuild for it to be worth the effort!
Here is a simple break down I put together...
-Built 2v 4.6-
Rotating Assembly: 5L Stroker 1700
Heads: 1200
Cams: 550
Long tubes and Mid pipe: Est: 600-700
Intake: Bullitt 1100, P-51 1200
Rough Est: 5300
-Cobra Head swap-
Heads: 2003 - 2 grand, 99-01 - $1000
Timing cover and Misc. assembly pieces - 300 to 400
Head Covers - 250
Intake - 375
Computer - ???
Rough Est: $2000 - 3325
-5.4 swap-
Nav 5.4 - 3200
Intake - 350
Transmission / clutch - ???
Computer - ???
Rough Est: Already close to 4 grand
This is purely an informational post. All prices assume you buy brand new.
00GT00 is offline
Old 05-21-2005, 01:00 PM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: Swells 03 GT
Code3 have you ever looked into getting a timing chain and heads off a cobra and converting to a 4V? I would love to do that... would that be cheeper/better then a 5.4l swap? I have no idea just spitballing here... Thoughts? Would I need anything other then the timing chain and heads? Someone help... and if you have prices post please!!!
When I looked into doing it. I looked at a 5.4 with Navigator heads. The cost for the conversion as well as the frustration for the small gains was not worth it, in my opinion. My ideal goal was that same 5.4 with 4V heads and a single turbo, but again the cost would be sky high, but it would make some sick HP.
The block for the 4.6 and 5.4 are identical with exception of deck height. Do a google search, you should be able to find some info.
Now, with that being said...please don't take offense, of what I am now going to say....But, it's like the old saying, "If you have to ask, you can't afford it". The cost for that type of conversion, which would include built motor, exhaust, clutch, rear end, flywheel, etc. would be well over $15,000.00. As I found out with this upgrade I did, the $$ starts adding up quickly and there are som many other things that pop up that you never think about.
code3GT is offline
Old 05-21-2005, 01:24 PM
nanaki
Retired MF Moderator
nanaki's Avatar
just get a blower for your 4.6 and be done with it.
nanaki is offline
Old 05-21-2005, 06:15 PM
Acer2428
Site Mod
Acer2428's Avatar
No, get forged internals and a blower for your 4.6 and be done with it.
Shii.... Get an 03-04 cobra and be done with it!
Acer2428 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: 5.4 Liter Swap????
