oxygen sensor
Old May 20, 2005 | 01:09 PM
hubada26's Avatar
hubada26
Default oxygen sensor
Does any one have any idea what wire coming off the oxygen sensor is the signal wire? or does any one have a wiring diagram of this for me to find it on my own? thank.
Old May 20, 2005 | 01:13 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: oxygen sensor
If you are wiring an A/F gauge...you DO NOT tap into the wire coming off the sensor. You use the signal waire from the ECU in the right kick panel.
Old May 20, 2005 | 01:19 PM
hubada26's Avatar
hubada26
i know that much the wires oming off the sensor are heat shielded, you have to at least tap into a wire after the connector to the harness. or find it from the pcm. i just need to know which one. anyone?
Old May 20, 2005 | 01:21 PM
code3GT's Avatar
code3GT
Mustang Nazi
You only tap into one wire on the computer. Let me try to temember. I think it's a gray wire with a green tracer. Let me find out fer ya.
Old May 20, 2005 | 01:25 PM
code3GT's Avatar
code3GT
Mustang Nazi
Mr car is an '01 and it's gray wire with green tracer. My friend's is an '02 and his was red with a green tracer.
Old May 20, 2005 | 01:28 PM
hubada26's Avatar
hubada26
well damn then thats going to be a problem...i am a mismatch of mustang years. i have a 2003 engine 01 tanny 98 computer and the list goes on. would you know about a 98?
Old May 20, 2005 | 01:31 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: hubada26
Not a thing. Do a google search on wiring diagrams for the '98 ECU.
Jb145700
Aug 21, 2022 06:37 AM
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
