F/I plus GEARS
my front end has ford racing C springs, BBK caster/camber plates, offset pinion bushings. stock rear end springs, both are sitting on 17in toyo proxes. Will be putting in a Procharger with 8 or 10 boost kit. Wanted to get my gears in before the blower was put in.
Full exhaust and 75mm throttle body/upper plenum as well.
4.10's are treated like gods on forums, but was just seeing how well that related to a blower setup.
I'd go with a set of 3.73 just because 4.1's+a blower will make it a very un DD car.
if you go with centri blower 4.10s work very nice for the street but you will run out of gear in the 1/4 mile but nothing bigger DR wheel could not fix. If you don't go to the track I recommend the 4.10s. No DRs with F/I means ****ty 60 ft times.
2010 Blue Ball Award Recipient
There's no reason to worry about running out of gear when you're out on the street anyways because if you're making that much power, there's no need to be dicking around at that high of speeds.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
