Innovate Wide Band Gauge
I have an autometer c2 wideband mounted in the car and use a innovative LM-1 when tuning. The autometer and LM-1 read exactly the same so the autometer is pretty good.
I have my afr set at 12.6 at wot, 15.8 at cruise and 14.7 at idle. They are the best settings I have tried so far.
On our cars (n/a) 14.3 to 15.0 is normal at idle and steady load "at speed". A WOT I will disagree wit the previous poster and say that 12.0 to 12,5 is optimal (I like it a bit richer than some because it lets you be a bit more aggressive with timing).
On closed throttle deceleration you'll see it go to 18+:1 and stay there 'til you give it some throttle--this is normal, the injectors shut down after 4 seconds of closed throttle (in gear) deceleration...
I believe a stock GT will enter coating fuel cut off at 850+rpm in gear and leave at 800rpm - in gear. Also I know the stock value for SCT, Sniper, and I think even diablo tuners is "4" but I don't believe its a 1:1 value based on seconds.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
09-08-2015 11:50 AM
