Squeeking noise, but stops when slight pressure is applied to clutch
I had the exact same problem, clutch was squeaking while foot was off at idle after hard shifting. i did this http://www.corral.net/tech/drivetrain/clutcha.htm
worked perfectly
clutch feels brand new and dosnt squeak now
i circled the tab that auto readjusts the clutch
its above the gas-brake pedel
turn car off and put in neutral, push back on the circled tab with a towel or something toward the front of the car - this hook moves when the clutch moves and clicks you can hear it when it readjusts
turn the car on and put the clutch in a few times and try it out. it seriously works
worked perfectly
Ya i got a bad one here! I hear a squeeking most the time until I barely put my foot on the clutch and it goes away. Most the time when I'm at drive-thru's or something it's kinda loud so I rest my foot on it for like 10 seconds lol. I hate tob's!
Don't replace it if just resting your foot on the clutch makes it go away. Simply get a Steeda clutch adjuster and double hook quadrant. It will cost you $80 for them, and if you take your time you can install them yourself fairly easy. I wouldn't opt for their cable as I've heard from numerous sources they are known to snap.
The two parts I mentioned will enable you to adjust the clutch enough to eliminate that sound. I've had multiple garages with a really good reputation tell me the same thing.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 11:50 AM
