Where do I find 4.6 dohc torque specs?
Old Jan 12, 2009 | 10:44 PM
boostanggt's Avatar
boostanggt
Default Where do I find 4.6 dohc torque specs?
I started assembly my 03' cobra motor and I am wondering if anyone knows where I can find torque specs for main caps, studs, ect. Thanks.
Old Jan 12, 2009 | 10:52 PM
ponycrazy2002's Avatar
ponycrazy2002
4.6L Torque Specs
Camshafts caps to head 71-106 in/lbs
Camshaft sprocket bolts 82-92 ft/lbs
Cylinder head bolts DOHC (four valve Cobra, and Mach One)
--Step 1 28-31ft/lbs
--Step 2 Tighten additional 90 degrees
--Step 3 Tighten additional 90 degrees
Drive belt idler and tensioner bolts 15-22 ft/lbs
Engine compartment brace bolts 15-22 ft/lbs
Engine mount to engine block bolts/studs 25-33 ft/lbs
Engine mount stud to crossmember nuts 95-126 ft/lbs
Exhaust manifold to cylinder head bolts 14-16 ft/lbs
Flywheel moutning bolts 59-64 ft/lbs
Ignition coil brackets to front cover 12-22 ft/lbs
Intake and side plates assembly to cylinder head
--Step 1 15-22 ft/lbs
Intake manifold to cylinder head bolts
DOHC (four valve Cobra and Mach One)
Upper plenum to intake 71-106 in/lbs
Intake to lower side plates 71-106 in/lbs
--Step 1 15 ft/lbs
Oil cooler to filter adapter insert
-1997-later 41-53 ft/lbs
Oil filter adapter bolts 15-22 ft/lbs
Oil pan to engine block bolts
-1997-later
--Step 1 15 ft/lbs
--Step 2 Tighten additional 60 degrees
Oil pick up tube to main bearing cap nut 15-22 ft/lbs
Oil pick up tube to oil pump bolts 71-106 in/lbs
Oil pump to engine block mounting bolts 71-106 in/lbs
Thermostat housing bolts 15-22 ft/lbs
Timing chain cover bolts 15-22 ft/lbs
Timing chain tensioners and guides 15-22 ft/lbs
Valve cover bolts 71-106 in/lbs
Vibration dampner to crankshaft bolt
-1997-later
--Step 1 66 ft/lbs
--Step 2 Loosen one full turn
--Step 3 36 ft/lbs
--Step 4 Tighten additional 90 degrees
Water pump mounting bolts 15-22 ft/lbs
Water pump pulley mounting bolts 15-22 ft/lbs
Wheel lug nuts 85-105 ft/lbs
hope this helps
Old Jan 12, 2009 | 11:08 PM
defconfire's Avatar
defconfire
I'm hoping you just copy pasta'd that because that was a lot to type.
Old Jan 12, 2009 | 11:19 PM
ponycrazy2002
some of it was copy and paste
Old Jan 12, 2009 | 11:29 PM
boostanggt's Avatar
boostanggt
That will do the job. Where did you get these?
Old Apr 15, 2020 | 07:34 PM
Jesse Gonzalez's Avatar
Jesse Gonzalez
Does this apply to the 2001cobra as well? Having a hard time finding the torque specs on the head and cam fasteners
Old Apr 16, 2020 | 07:01 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Head bolts: step one tighten to 30ftlbs, step two rotate additional 90 degrees, step 3 loosen bolts one full turn. step 4 tighten to 30ftlbs, step 5 rotate additional 90 degrees. step 6 rotate additional 90 degrees
Cam caps are 89 inch lbs. Secondary cam sprocket is 37ftlb
MadMan@TheWheel
Jul 20, 2010 03:48 PM
stamper5.0
Mar 7, 2008 04:02 PM
MadMan@TheWheel
351 Mustang
Oct 31, 2007 02:28 PM
Kickinwing77
351 Mustang
Aug 28, 2007 12:50 PM
68SCode4speed
Dec 24, 2006 01:48 AM
