4v engine install
Old Jan 17, 2009 | 12:40 PM
GT35thconvertable's Avatar
GT35thconvertable
Default 4v engine install
i am getting ready to install my 4v swap and not sure if i should go from the top or bottom considering i have bbk longtube headers. i have dont this 20 times on a 2v but im sure 4v is alot tighter
Old Jan 17, 2009 | 02:07 PM
BraMas's Avatar
BraMas
It will go in just fine from the top. But if you have the ability to put it in from the bottom I would do it that way.
Old Jan 17, 2009 | 02:31 PM
mustangman36578's Avatar
mustangman36578
it will not go in just fine from the top with the lt headers installed if you have the stock k-member. i tried fron the top and you will either be hitting on the k-member or on the firewall. what i did is took out all but one bolt for the headers so that i could wiggle them around as i lowered the engine into place and once i got them under the firewall i installed the rest of the bolts. it wasnt too bad that way but if you have the equipment to go from the bottom that would be the easiest.
Old Jan 17, 2009 | 05:50 PM
GT35thconvertable
Default lift
i have a lift i just didnt know how difficult it would be getting the stock k member off considering calipers rack and pinion and ya know the rest..thanks for the input still dunno which would be the best.i have install headers 20 times when it was a 2v but never tried with the 4v..keep the info coming
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
Design1795
Jan 24, 2017 10:38 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Design1795
Aug 24, 2015 04:41 PM
