NEED HELP!!! IMMEDIATELY PLEASE!!!!
Old Jan 18, 2009 | 02:36 AM
irionman88's Avatar
irionman88
thanks!! i need that write up asap so i can decide weather to do the swap or not. how complicated of a swap will this be?
Old Jan 18, 2009 | 10:35 AM
mustangman36578's Avatar
mustangman36578
its not too bad. it will drop right in. never did it with the 03/04 supercharged one though so i think you will run into a few other modifications to your wiring harness if you go with that one.
Old Jan 18, 2009 | 10:47 AM
irionman88's Avatar
irionman88
I am trying to get an idea of what type of problems the school is goin to run into and the modifications needed for the install to work. I don't see extending the wiring harness being a problem or mounting a new heat exchanger or reservoir will be either. I just don't know if they will be able to reverse the polarity of the wires or not if you have to do so. Also i have to get a whole list of parts so i can purchase the parts before i leave this week.
Old Jan 18, 2009 | 10:59 AM
irionman88's Avatar
irionman88
i also read i will need a cobra fuel pump or i believe ive read about individuals using dual gt fuel pumps. I heard that the stock hood wouldn't fit because of the fuel pump i believe. is this correct
Old Jan 18, 2009 | 11:16 AM
irionman88's Avatar
irionman88
which wiring harnesses will i have to use and is there any mods to the wiring harnesses?
piotrek53
Oct 13, 2015 06:54 PM
Spiral534
Oct 6, 2015 04:31 PM
Sminemann
Sep 17, 2015 09:24 AM
MusicCity615
Sep 12, 2015 07:05 AM
