MAF
well when i used the scanner it said "MAF Low Air Input" or something like that so I cleaned everything and it didn;t do anything, so I figured it was the MAF and I was positive when my car refused to idle until i unpluged the MAF and now it runs but i NEED to fix it. That check engine light is pissin me off.
Wow I didn't know that they went bad. If you've cleaned the little filament sensor with a soft brush and the appropriate cleaner and that didn't work then I guess you are lucky to get to upgrade your MAF!
Theres no point in buying a 80mm MAF and calibrating it to stock 19lb injectors, your not gonna gain any power, then if you want to supercharge your car your going to want a 90mm one. The only way that 80mm is gonna help is if you go above 300 RWHP n/a and it will be good. Then w/ FI you will want a 90mm MAF. So you should decide if your going to udgrade your car, if your going to stay N/A or FI.
jwog666
Dec 27, 2021 08:09 PM
stangin1996gt
Sep 21, 2015 11:01 AM
