Forged internals benefits?
^ he was talking about bore, when you bore .020 it becomes 283.5 ci.
he assumed since the cubes increased the liter would also. I think thats correct but it wouldn't be noticable with a bore that small, maybe a 4.7 or a 4.65 lol.
Their are only two reasons to rebuild a motor: 1. its bad, broke and in need of repair. 2. You want more out of it than the stock design will give. There are lots of engine rebuilds that do not use forged internals. The only reason to put forged internals into your motor is that they are much stronger and they will allow you to exceed the limits of stock internals. During the rebuild you can also decide on the stroke, bore and compression that is right for your application.
Whether you need forged internals depends upon your goals for the motor. Do you want a supercharger? If your motor has been well maintained, then an introductory supercharger that doesn't exceed 370-380 rwhp should be fine. This is 60-65% above the motors stock rating but with a proper tune a well maintained motor should handle it. The more you go above that, the greater the risk. The greater the risk, the greater the need for forged internals that are specifically designed to handle the power.
Not, on a stock block unless they use sleeves. You need to get a stroker or the new Boss block. Ford now produces a 3.7" bore modular Boss 302 block that can get you to 5.0 with the standard stroke.
For a daily driver that sounds like a good plan. A P-1SC with the standard pully on a stock motor should yeild 350 rwhp. Maybe more because of the long-tube header. You definitely to crawl immediately to a dyno (d/n exceed 2500 rpm) after installing the supercharger if for nothing else than to check the canned tune. The dyno can identify if you have peaked the MAF. If you have you can either get a new MAF or a Diablosport MAFia which adapts the signal of the stock MAF for higher air flow.
No. The MAF (mass airflow meter) and spark plugs are extra. I can't remember is the fan belt came with the kit or not.
The MAF is a separate component that is located along the cold air piping. ProCharger's piping moves the MAF into the fender well. According to ProCharger, the stock MAF is OK with the standard 8 lb pulley. If you order the 10 lb pulley they recommend the Ford Lightining MAF. This is on completely stock engine though. Other mods, such as TB/Plenum and Long-tube headers, may also make the airflow greater than the stock MAF can measure or signal to the computer so it basically pegs out. It has reached its maximum voltage and can go no higher. When that happens the engine is getting more air, but the computer isn't injecting more gas which results in a lean air/fuel mixture. Lean could lead to detonation. Detonation could lead to a blown up motor.
The Lightning MAF is able to measure more airflow than the stock MAF. You can also get a Diablosport MAFia (This is what I have.) which changes the voltage signal from the stock MAF to the computer. It has various settings which make the stock MAF capable of measuring huge amounts of airflow.
09-17-2015 07:57 PM
09-08-2015 11:50 AM
