tires
#22
Perfect
Tires are 25.6" & 25.7" diameter front/rear, respectively. You won't have any clearance issues on fenders and your ABS sensors will not even blink at different diameters.
Just need to confirm weather +20mm or +40mm off-set is good for the look/fit you want in BOTH front and rear. Do the following to assure the look you are after. Remove one front and one rear wheel. Measure the back-space of each. I think I already gave you a link, but in case I didn't, go ***HERE*** to see how it is done. Look on the off-set/back-space numerical chart on the same page and convert those numbers to off-set.
If confusing, just post the back-space of the wheels CURRENTLY on your ride. Call TSW and ask what the back-space of each particular wheel you consider for BOTH front and rear.
I can help you figure out EXACTLY where the wheel fit on your ride
HTH
Jazzer
HTH
Jazzer
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
