96 Mustang gt stalls after putting into park
Old Apr 3, 2009 | 11:28 PM
2slow4me_need2makefaster's Avatar
Default 96 Mustang gt stalls after putting into park
just the last 24 hr. my 1996 mustang gt stalls after a short or loong drive when you put it into park?
Old Apr 4, 2009 | 07:59 AM
grogan's Avatar
grogan
check ur iac. could be dirty or bad
Old Apr 4, 2009 | 03:16 PM
Default but it only does it when i put it in park from drive
is there some sort of vacuum leak ? is there even vacuum going to the trans? and it only does sometimes others it just idles really low like 400 or 500 but it just started doing this after a battery disconnect for clearing codes? maybey its re learning the idle? my moms 2005 Mazda 3 4cyl does it oif you disconnect the battery it has to relearn its idle and all that stuff wonder if its the same idea?
Old Apr 7, 2009 | 10:52 AM
solved it i cleaned my map sensor the sensor behind it and clean the throttle body runs perfect. thanks for the the help!!
djbigskrilla
Sep 20, 2022 01:04 AM
stanngg
Aug 12, 2015 03:43 PM
daytooday
Aug 11, 2015 09:22 AM
01blackgtconv
Aug 10, 2015 01:25 PM
dfw692
Aug 7, 2015 11:53 PM
