Possibly Intake Crack
Old Apr 18, 2009 | 12:37 AM
defconfire's Avatar
defconfire
Default Possibly Intake Crack
I always knew someday my intake manifold would crack, but Im not sure if today is that day. I think I may have a hairline crack between the base of one of the runners and the coolant passage.
I'm not sure if I'm losing coolant but I am getting coolant smoke on startup.(start up smoke seems to be problem w/ me).
I think the coolant could be sitting on the valve and being dumped in and burnt off on startup.
I havent heard of anyones intake manifold cracking gradually so im not sure if this is actually the issue. Does anyone have any other possible ideas or do you all think I hit the nail on the head with the diagnosis?
Old Apr 18, 2009 | 10:49 AM
defconfire's Avatar
defconfire
I'm guessing I got it right then if no one has any other suggestions.
Old Apr 18, 2009 | 12:23 PM
black35th's Avatar
black35th
I think you hit the nail on the head. My intake cracked slowly, it started off not being that bad and being driveable. I was doing a little sprint one night with my buddy and it blew wide open.
As far as the smoke, I never had that problem. My best advice would be to check the valley real good. When mine cracked it puddled up in the valley real bad.
Old Apr 18, 2009 | 02:10 PM
stangalator's Avatar
stangalator
i have an idea to test this, its basically a leak down test for your intake. I'll take a picture of what i made to test mine later. Basically what i did, is make an apparatus that will push in a regulated 20-30 psi in the intake with the engine stopped. On a completely sealed engine, there should be no leaks. However, with a crack you should hear and feel air coming out of the intake.
Hope this helps! I made mine out of PVC piping, its not hard at all to make
Old Apr 18, 2009 | 03:18 PM
defconfire's Avatar
defconfire
I think mine may have cracked differently than most/every other intake manifold. I fully checked the valley with a UV test. And it looks bone dry. I really need to pressure test the system.
I think mine may somehow be leaking directly into one of the intake ports. I replaced the intake gaskets not that long ago so I doubt its that.
Jb145700
Aug 21, 2022 06:37 AM
04stangman
Sep 17, 2015 01:45 PM
J.casone400
Sep 12, 2015 10:01 PM
Blk Vert
Sep 9, 2015 12:16 PM
