collapsed lifter?
Old May 8, 2009 | 02:04 PM
95crownvic's Avatar
95crownvic
Default collapsed lifter?
a 95 crown vic 4.6. i think i have one, after watching some videos its sounds just the same. anyway i can tell which one without replacing them all? the car sat for about a month and then i started it and bam, the car is getting sold i dont wanna drop a ton of money in it. i have the drivers side cam out and took all the lifters out but i cant really tell which one is collapsed?
Old May 8, 2009 | 03:09 PM
Chris@GMS's Avatar
Chris@GMS
Banned
The easiest way to test them if they are out, bleed them down, and check for slop. once they are bled down you can sqeeze the lifter but there will be spring tension, so there shouldnt be any slop, if there is slop then the lifter is bad. also you might want to look at your chain tensioners, they might be going out. good, luck.
Old May 11, 2009 | 06:51 PM
95crownvic's Avatar
95crownvic
how do i bleed them down?
Old May 12, 2009 | 01:34 PM
Chris@GMS's Avatar
Chris@GMS
Banned
the Easiest way is to put them im a vice and slowly compress them. till they bottom out. but dont do it to fast and do not crank on it when they are bottomed out.
WDScott
Aug 17, 2015 06:38 AM
ding56
Aug 14, 2015 02:40 AM
Stinger
Mar 28, 2004 09:06 PM
fasteddie
Mar 1, 2004 04:45 AM
w11988
Dec 9, 2003 06:41 PM
