auto to t-56 swap?
auto to t-56 swap?
well i found a 2001 GT for sale locally for only 3k, but it has an automatic. what would be involved in swapping for a t56? I figured if i'm doing the swap i might as well go to the t-56 right away instead of a t45.
Alot. You would have to swap over the pedal assembly,clutch cable,clutch,flywheel,tranny,crossmember, bypass neutral safety, and im not positive but when i swapped over a 95 gt to a t5 i had to put in a manual ecm.Just get a tuner to adjust shift points and firmness and put a higher stall converter and keep the auto.
Pepe by T-56 swap thead and may be of some help
I went from man to man so less work than you. My last girlfreind also went man to man.... so I dumped her
Jazzer
Jazzer
Jazzer
Jazzer
Well the things that I can remember off the top of my head on my auto-t56 swap is, dshaft, crossmember, flash/tune, tranny, bellhousing, pedals, bezel, and shifter.
Matt's 95 Stang
10-05-2015 07:16 AM
