wiring help?
wiring help?
short n simple, can i run a relay to turn my headlights on when i turn my brights on? one pin is ground, one pin is gonna be constant power which is connected to the other pin which between the two are normally open inside the relay(this pin goes to the headlights then), and then the other two pins are for the brights. thats sorta what i drummed up, if that makes sense. will that work wiring gurus?
If low beams, you do not want them on with the brights as they will make a bright spot in front of the car that will screw up your long distance acuity in the dark...
sorry yea i was referring to the low beams. and to the post above, i do actually have the silverstars. the problem im havin is that with my projectors is the the high beams are aimed way to high when the headlights(low beams) are aimed perfectly. i dunno i just thought throwin em all on at once would help the lack of lighting being thrown onto the actual road with the brights on.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
