Would it be pointless?
Old Jun 28, 2005 | 12:42 PM
josh4rim's Avatar
josh4rim
Default Would it be pointless?
Would it be pointless to put a 75mm TB on without doing the Plenum and intake. Would it only function at its lowest point of are flow? Is 75mm a good size to go with on a pretty much stock 2k GT?
Old Jun 28, 2005 | 01:03 PM
Acer2428's Avatar
Acer2428
Site Mod
Default RE: Would it be pointless?
Yes.
and a 70mm would be better IMO.
Old Jun 28, 2005 | 01:07 PM
David_K's Avatar
David_K
no it wouldnt be pointless. its still a modification that you will see great benefit from in the future. are you planing on getting an upgraded plenum? If not i would put that money aside and purchase some 4.10 gears
Old Jun 28, 2005 | 01:17 PM
SilverGTV8's Avatar
SilverGTV8
You wo't see any benfit now with just a TB. For 300 bucks from RPMoutlet you can get a Accufab and a C&L plenum. If you are going to swap the TB might as well do the plenum while you are at it.
Old Jun 28, 2005 | 02:00 PM
josh4rim's Avatar
josh4rim
ORIGINAL: David_K
4.10's are on order right now. Intake is the next step!!
Old Jun 28, 2005 | 02:26 PM
David_K's Avatar
David_K
then i would spend the money on an intake first
Old Jun 28, 2005 | 05:47 PM
JT2000's Avatar
JT2000
Does FRPP make a bigger plenum for a 75mm TB? I want to modify the upper intake but I'd rather have a pony staring back at me than the words Accu-Fab.
Old Jun 28, 2005 | 06:24 PM
SilverGTV8's Avatar
SilverGTV8
I know of people who removed the pony from teh stocker and stuck it to the accufab.
If you go with the accufab plenum the 70mm provided better numbers in a NA application then the 75mm, if you go C&L the 75mm is recommended.
Old Jun 28, 2005 | 07:51 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: josh4rim
Pointless no, not worth the money right now, probably. Unless you plan on getting a different cam or SC or Turbo, your stock intake and even a 70mm will be plenty. But if you do the intake, might as well do it right and do the plenum as you have thought of.
Old Jun 28, 2005 | 09:12 PM
Blk_96_GT's Avatar
Blk_96_GT
i dont think a 75mm tb will fit on a stock Plenum, will it? so if it dosen't fit, then it would be poinless because you could'nt put it on. IMO i think for a pretty much stock would be over kill, untill you get some other mods.
blazen351
Jun 12, 2006 07:52 PM
SOLDSHORT
May 22, 2006 06:52 PM
Melon
Apr 19, 2006 03:18 PM
valley firearms
Oct 2, 2005 01:56 AM
freeunit
May 15, 2005 12:16 PM
