runs funny with the hvac on?
hmm - mine does this too. Do you really think there's a leak? I just thought that since the a/c used the engine to work, it was the extra drag from that. It does sound like I'm revving my engine at stop lights though.
had this happened to me, only got idle surges with the a/c on and sometimes some hesitation when accelerating. What i did is disconnected the battery for 20 minutes, reconnect it and followed the procedure to set the idle correctly in my owner's manual and now I don't have this issue anymore. I suggest trying this first.
The heater controls are controlled by vacuum lines.When you adjust your setting vacuum is what opens and closes the doors.So its probably behind the dash,pull out your control panel and see if any lines have obvious holes or cracks.
isnt there vaccum lines that run to the engine? i dont remember it doing this before the pi swap and new tb/plenum.
does a vaccum leak effect anything besides the hvac? cause the a/c not to blow cold?
