LSD
Old Jul 9, 2005 | 03:33 AM
rbstang's Avatar
rbstang
Default LSD
Im looking into a Limited Slip Diff i was wondering if anyone had any suggestions on which one to get. I was thinking maybe Auburn Gear High Performance Limited Slip Differential or the Eaton 10 Bolt Posi Limited Slip Differential.
Old Jul 9, 2005 | 05:08 PM
SilverGTV8's Avatar
SilverGTV8
Default RE: LSD
The auburn gear is nice. Just make sure it is not a locker and you will be all set.
Old Jul 9, 2005 | 10:09 PM
BenScharf's Avatar
BenScharf
Default RE: LSD
I thought the GTs came with a LSD
Old Jul 10, 2005 | 03:49 AM
rbstang's Avatar
rbstang
Default RE: LSD
Thanks SilverGT. Ben I dont think they come with LSD's i think they come with open differential and traction control. When you lose traction the brakes slow the wheels down and thats supposed to be the LSD i think but when i burn out im only burning one tire... great LSD ford gj
Old Jul 10, 2005 | 12:05 PM
SilverGTV8's Avatar
SilverGTV8
Default RE: LSD
GT's come with T-loc. It is a real weak posi set-up and typically wears out after 40,000miles with hard use. It can be rebuilt. If you are going to change out the diff, you might as well step up to 31 splines and a c-clip eliminator kit to make a very strong rear end.
AND Traction Control does NOT apply the brakes!!!! Traction control cuts fuel to reduce power to the rear wheels. If it applied brakes it would be called stability control.
Old Jul 10, 2005 | 12:37 PM
BenScharf's Avatar
BenScharf
Default RE: LSD
Damn that's worthless...
nonstopred
Jul 31, 2006 12:34 PM
V6MustangKnight
Jun 20, 2006 10:03 PM
HxCory
Jun 2, 2006 06:15 PM
TJ
May 16, 2006 08:52 PM
Big Red
Mar 6, 2006 10:25 PM
