Low Oil Sensor and other questions
Old 10-27-2009, 09:45 AM
GreenStang94
GreenStang94's Avatar
Default Low Oil Sensor and other questions
Hey guys, been a while since i've been on here, but i got myself another Mustang and need some questions answered. First off i upgraded from a V6 to a V8, so its a new animal for me to tinker with. After i got the car the Low Oil light came on the dash, although the oil is at the right operating level. So i thought that the sensor is stuck or failed, i called the local parts store to find out that there apparently isn't a Low Oil Sensor? I was confused, i know the 5.0 has one, but does the 4.6, and if so where can i get one? Lastly, are there any trouble spots that you know of and i should address soon?
GreenStang94 is offline
Old 10-27-2009, 06:06 PM
1996stang
1996stang's Avatar
Im pretty sure they do have one becuase my "low oil" light comes on all the time even though I never let my oil level drop below operating levels, you can try reseting your computer to see if it clears the light, otherwise if you have good oil pressure I wouldnt worry about it (somone correct me if Im wrong). As far as trouble spots, just drive the car, get used to it and then you will see the quirks that need to be worked out, like when I got my car it needed a new exhaust, plugs and plug wire changed, and new struts and shocks. My mine thing right now though is not enough power but that will all change soon considering I just ordered a set of PI heads and some other goodies last night.
1996stang is offline
Old 10-27-2009, 06:23 PM
JC316
JC316's Avatar
It does have a low oil sensor. It's in the pan, near the oil drain plug. Usually they come unplugged.
JC316 is offline
djbigskrilla
09-20-2022 01:04 AM
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
musnicki
09-23-2015 07:11 AM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Itzjoe
08-26-2015 08:15 PM
Quick Reply: Low Oil Sensor and other questions
