??07 4.6 motor/trans in a 97 v6 mustang??
k member will work fine.
you will need to swap out the rear end for an 8.8 cuz the 7.5" isnt strong enuff
go to loganmotorsports.com and get one of their adapter kits. you can use a cobra throttle body, 2v headers, etc... you will need some adjustable cam gears to eliminate the variable cam timing or whatever the 3v has. or you can go the harder route and swap over the ECU and everything from the 3v and keep the variable timing and throttle. depends which route you want to go.
More money and modding than you expect, I'm sure.
http://sn95forums.com/index.php/topic,32849.0.html
10-09-2015 03:27 PM
