Heads
Old Jan 17, 2010 | 02:14 PM
Warrior1876's Avatar
Warrior1876
Default Heads
Is getting heads redone at a machine performance shop as good as buying say patriot or trickflow heads.
Old Jan 17, 2010 | 03:18 PM
Z28KLR's Avatar
Z28KLR
I don't know a whole lot about heads, but I think that if the shop working on your heads is a good shop and familiar with Mustangs then you should be able to get something comparable to what Patriot sells. Patriot (and everywhere else's) heads are basically milled/reworked stock castings, the Trick Flow's are so far the only new (not OEM) casting, and those things are supposed to be bad ***. The various write ups I've seen so far in the Mustang mags (MM&FF, 5.0) are basically saying that the Trick Flow's are worth about 20-30 h.p. more than Patriot's or other's reworked stock castings.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
