Ati procharger pulley
Because of belt slippage ProCharger doesn't recommend pulleys smaller that 3.0". The ProCharger 8 lb pulley is 3.8". They say you get approximately 1 addition pound of pressure for every 1/10" smaller pulley. Going to a 3.0" pulley will produce somewhere around 16 psi. They make special after market 2.8' pulleys that may give you an additional 2 psi. If you are trying to get that much you should install an overdrive crank pulley. It will spin the suprcharger faster without putting pulleys on that are too small for a 6 rib belt.
Here's one place. I've never bought anything from them so I have no recommendation either yea or nay.
http://www.houseofboost.com/store/en.../prod_106.html
Innovators West crank pulleys are nice, that's what most people running the OD cranks are using I believe. They don't have a 6 rib OD pulley as far as I know, though, only an 8. But honestly if you're looking to produce that kind of boost you might as well do an 8 rib conversion anyway.
Dragonus18
09-09-2015 01:21 AM
