need help/advice
My car just rolled over 70,000 and i have never had a problem. On the way home i noticed my car started running rough. I made it home and the motor was running rough and had a mild shake to it, also i was getting white smoke out of the tail pipes. When you start it up it smells like straight gas and when you shut it off white smoke pours out of the passenger side tail pipe. Also in the passenger side tail pipe i noticed a yellow thick liquid which smells like a gas/oil.
If any has any advice or help they can give me on to way my car might be doing this i would greatly appreciate it
Thanks
__________________
Thanks
__________________
you might be burning coolant in one of your passenger side cylinders. at least white smoke points in that direction...depending on how bad the head gasket failure is (if it actually is that) there may be coolant in the oil pan. you can check your dipstick and if there is milkshake lookin gunk on it then it would seem to be a head gasket failure.
Because its on open loop mode the car runs rich until it leans out at operating temp. However my car dosnt like REEK of gas but its noticable...Fuel leaks maybe? White smoke is usually headgasket or coolant of some sort. See any lose of power or compression? Maybe do a compression check and yes if you check ur oil and see any milkshake or smell of coolant its headgasket time.
DamageIncNY
Feb 7, 2015 05:25 PM
