Need some help with PI intake
My intake cracked so I got a new one and have Finlay gotten around to installing it. the alternator posts on the new aluminum intake are different from my full composite intake. is this the wrong part or is this a common issue?
from what I have found out I will have to go with the older bracket to mount my alternater as the posts on the pi are on the cross over and mine has 1 on the cross over and the other is further back on the intake.
ok here is the skinney, you can get just the intake like i did and have to find the bracket or if your talking to the right person when buying it they will sell you the kit that comes with the bracket. the new bracket is $20 from ford so I have that on the way.
you have an 02 so yours should have the aluminum cross over already. His cracked more than likely like mine did at the thermostat housing. so i dont know where yours would have cracked? are you losing coolant or something?
I got luckey on mine breaking, it broke off at the post where the heater hose connects in the driveway but after removal I can see a crack where the T-stat is and that is where I was loosing my coolent. just happy it didn't happen on the road. Will have her back on her feet by this weekend.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
