Recharging my AC lines
06-03-2010, 01:25 PM
it sounds more like a bad water pump or a blown head gasket or the 1st casued the latter. If ur heater isnt working its likly due to no coolant flow witch could also be the problem of the over heat situation.
Either way once yo fix it put in a new t-stat most of them dont like to be that hot and will cause over heating problems them self after they have been cooked.
06-29-2010, 03:29 PM
OK i tested the pressure on the freon line with the car OFF and it read in the danger mechanical problems zone.
06-29-2010, 03:33 PM
Quote:
Originally Posted by
watman02
a blown head gasket .
... what... It just over heated from a clogged thermostat, I took it out and the car is fine now until winter.
07-27-2010, 09:48 PM
How many lbs of a/c is used in a 1996 Ford Mustang GT?
07-28-2010, 02:19 AM
COCHO
are you talking R-12, if so a little over 2
02-07-2011, 04:27 AM
SXGT
not sure what this meant?
02-07-2011, 02:52 PM
SXGT
It means that you dont know what you are doing. Just take it to some one who does.
02-07-2011, 08:44 PM
06-05-2011, 07:07 AM
no more radiator leaks or overheating.
back to the EVAP.
how much can i access just from the glove box
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
TCStangerv6
10-11-2015 05:57 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
96 ,
ac ,
big ,
ford ,
lines ,
low ,
mach ,
mustang ,
one ,
port ,
recharge ,
refill ,
side ,
small ,
v6
