fuel pump is broken
Also check the module\ relay under front pass fender for power.
It controls your fuel pump , cooling fan and AC.
Also there is a module in your trunk on driver side mounted to wall that could have failed.
Good Luck
Good Luck
true, the drivetrain and all of the wiring was pulled from a car wrecked in the rear. it was left sitting for about 5-6 years open to all of the elements, so the rear module in the back could be the problem, i'll try to troubleshoot once the rain stops here lol
LOL^^^ Good Luck...crimany that's going to be a nightmare.
Damn dude, i just threw away a perfectly good used fuel pump. When my crankshaft sensor went bad, i thought it was fuel pump and replaced my fuel pump with a new one. Cleaned out the garage the other day and junked it. I would have given it to you. I guess i shouldn't tell you this now huh??
mrappe
09-26-2015 10:16 AM
