Squeaking and creaking!
Old Nov 10, 2010 | 11:54 AM
Case's97GT's Avatar
Case's97GT
Default Squeaking and creaking!
Okay well I have 2 sounds. My car makes a creaking noise when moving up and down. Obvious right? I don't want to have to replace a whole bunch of stuff if I don't have to. and then My car Squeaks when turning but only at slow speeds, like when i'm turning around. I haven't checked anything out yet. just trying to get an idea of what all i might be looking at,.
Old Nov 11, 2010 | 05:20 AM
uberstang1's Avatar
uberstang1
Chupacabra
More information is needed here. Is the noise coming from the front or the back of the car? Can you narrow it down to a specific wheel or other area? When you say moving up and down do you mean like pushing down on the truck for example? Theres a slew of things it can be such as springs/struts, spring isolators, control arm bushings, a-arm bushings, tire rod ends, sway bar endlink/bushings.
Old Nov 11, 2010 | 12:30 PM
Case's97GT's Avatar
Case's97GT
I can't seem to figure which side is making the squeaking noise but it is the front obviously i think it may be the LH side. and the creaking sounds like the springs are making it on the LH rear.
Old Nov 11, 2010 | 05:40 PM
uberstang1's Avatar
uberstang1
Chupacabra
The rear could be a worn isolator or a shock, the front could be a number of things to broad of a description to narrow it down.
Old Nov 11, 2010 | 05:48 PM
fidelcastrol's Avatar
fidelcastrol
More than likely 2 problems, lube the control arm bushings and the steering rack bushing defect causing the creaking while turning slowly, use cliffyk's method on his website to repair the rack defect.
edit: use lithium grease to lube the bushings on the control arms
Old Nov 11, 2010 | 05:52 PM
FOURSIXALLDAY's Avatar
FOURSIXALLDAY
im thinking it would be the shocks as well my car was doing it and i replaced my suspension with new and the noises went away. but i cant say for sure without actually hearing the noises.
Old Nov 11, 2010 | 05:55 PM
fidelcastrol
That's also possible, how many miles are on your car? Post up a video of the car making the noise.
flash_xx
Sep 21, 2015 01:25 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
sabearn
Jun 14, 2005 08:16 PM
birdman076
Apr 24, 2005 11:23 PM
stock_95gt
Feb 2, 2005 03:26 PM
