a/c messed up perhaps?
Old Feb 17, 2011 | 04:33 PM
Endrance's Avatar
Endrance
Default a/c messed up perhaps?
When I have the a/c on the rps fluctuate between regular idle and about 850-900. Although I expect this, it seems that its doing it too often. Every 30 seconds or so. Is this normal? Also a side note, if I were to get a thermostat what should I go with?
Old Feb 17, 2011 | 06:09 PM
BraMas's Avatar
BraMas
if the A/C clutch is engaging every 30 seconds you probably are low on R134A Refrigerant
Old Feb 17, 2011 | 06:53 PM
65mechanic's Avatar
65mechanic
I had a similar problem. Whenever I turned on the A/C or defrost (which turns on the A/C) the rpms would jump up and down at stop lights and blow warm air. I thought it was my IAC so I got a new one and that didnt fix it. I then got on mustangforums and found that it was the A/C recycling switch. Its about $13. Hope this helps.
Old Feb 18, 2011 | 11:32 AM
Endrance's Avatar
Endrance
Thanks a lot ill look into both. I haven't really put any refrigerant since I bought the car so that is a huge possibility.
Also, after turning the a/c on that cutting it off, I notice that my rpms would hang, but in the way that perhaps my iac is messed up (this will be iac #3). It seened to have activated my iac getting stuck anyone experience something similar?
Old Feb 18, 2011 | 12:59 PM
Repzard's Avatar
Repzard
What this member said. Its trying to build pressure and cant.
Id check for a leak also with a color dye refrigerant.
Old Feb 18, 2011 | 03:43 PM
harbre32's Avatar
harbre32
i would just try charging it first and go from there. most likley its a very small leak that may take a year to notice.
vargas
Jun 17, 2017 12:17 PM
breaking
Oct 2, 2015 01:27 PM
69Volunteer
Sep 30, 2015 10:39 AM
Wombatnation
Sep 13, 2015 09:16 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
