Last edit by: IB Advertising
Browse all: Brake Guides
- Ford Mustang V6 and GT 1996 to 2014: Why is My Brake Light On?
Guide to diagnose trouble and recommended solutions
Brake light on dash has a mind of its own help!
Why not just check your brake fluid. It takes 5 seconds, and is most likely your issue. The reservoir has a fluid level sensor. When fluid is low, the brake light comes on.
My guess, the fluid level is at, or just below the sensor. When you make a turn or hit a bump, the fluid splashes on the sensor and the light goes off until the fluid isn't touching the sensor anymore.
Brake fluid is fine. But even if it wasn't that still wouldn't explain why the brake light is off even when I pull the e-brake up. uberstang; I fill the coolent when it's low but it seems like it goes up and down quite frequently. Anyways could you post those pictures of that e-brake cable you were talking about? BTW guys I just got a V1 thought I'd share the good news got to hard wire it soon!
Ok just took the pics, here they are. Was a little different that I remember its actually a white plastic plunger switch. It has two wires attached to it and attaches to the ebrake bracket via one shet metal screw which goes on the top right hole and the dowel goes in the bottom left hole.
