2002 GT normal fuel pump duty cycle
If it is reading the PID 1673 (IIRC) it should be 5% to 50% depending in engine speed/load/etc.
The PCM sends a 5% to 50% duty cycle to the fuel pump driver module which then powers the pump at 10% to 100% of full capacity. The FPDM returns a 50% d/c signal to the PCM to indicate all is well.
Signals from the PCM of 0% to 5%, 51% to 67.5%, or 82.5% to 100% are invalid, the FPDM will return a 25% d/c signal to the PCM.
A PCM signal of 67.5 to 82.5% command the fuel pump off, the FPDM will return a 50% d/c signal to the PCM.
Then what your are seeing is normal, Pinging can be caused by too lean a air/fuel mix, too advanced ignition timing, and/or one more "hot spots" in the combustion chamber (including plugs that are too "hot".
You need to monitor the fuel pressure, timing, and AFR (a wide band O2 system is needed for this) to determine the actual cause or causes.
tramphardrocker
Sep 13, 2015 08:56 PM
