First Cylinder 5 now 6 WTF?! HELP!
ok i know im posting like a maniac here but i just let the car cool down for like idk 2hrs and then turned it on and got no codes or misfires, so i decided to drive the car down to my walmart and back (about 10mile round trip) and got no codes or misfires, does any of this make sense can the COP misfire sometimes and then not at other times? im stupped, or do i just need a bama custom tune to recalibrate everything from stock to custom? thanks guys
I had a misfire when corvette would get warm but not when car was cold.
Now for the reason it was missing when hot was the fuel injectors would fail under hot condition because the coils in injectors would drop in ohms and not spay.
This could be the same problem you are having with your COPS.
They are working good when cold but maybe failing somewhat under heat.
heat on electronics make them act funny, specialy solid state electronics.
Just wanted to state this could be what is happening to your COPs under heat or load.
They are coils and so arent fuel injectors in a way ( solenoid is anyways) could be a problem your having.
Coil power drops under heat.?
Just my 2
GL
its throwing a #5 code first right? replace #5 and go from there, dont pay pepboys to touch your car please. Replace the known problem coil first and go from there. Like I said before one bad coil will cause others to go screwy from bad rf signals and whatnot
im gona replace #5, gona cost me like 40-50 bucks for an oem one but ill give it a shot, btw just drove the car again tonight no misfire or anything, kind of mysterious if u ask me, sounds like it isn't making a good connection or something?
well lads the problem is solved replaced cylinder #5's COP and bang! instantaneous the CEL went away and by god no more misfire and to my surprise no more hesitation or "hiccup" when i accelerate hard, i didn't know thats what was causing my car to kinda hesitate for a split milisecond when i was pushing it, im so happy this fixed 2 problems not just one! thanks guys i couldn't be happier right meow! i did a pull on the highway up to 100mph and felt amazing no more "hiccup" and perfect acceleration and timing, im beyond happy with it, feels like a totally different car with that hiccup gone! thanks again guys, i can't say it enough!
I learned several years ago with my expedition that when it started missing, the first thing to check are the COPs. These things will run you in circles trying to figure it out. Better off just to replace and move on like WhitefoxGT said. Glad you found the issue....no you know.
